Einleitung
If you need to replace the battery on a Acer Aspire TimelineX 4820T-6645 this guide will show you how to do so. You will not need tools to complete this replacement, and it is a fairly simple process.
Power down the laptop.
Turn the laptop over so the bottom is facing up and the battery is facing towards you.
The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
Slide the left tab to the left and hold it there.
While holding the left tab to the left the battery should easily pull out of the laptop.
