Zum Hauptinhalt wechseln
Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Place laptop bottom side up, and use a Phillips #1 screwdriver to unscrew the five 8 mm screws from the back panel.
  5. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • After removing the back panel, use a Phillips #1 screwdriver to unscrew the two 8 mm screws that hold the retaining piece to the frame.
  6. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Pull the plastic tab toward the frame to disconnect the hard drive SATA.
  7. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the hard drive from the laptop, and use a Phillips #1 screwdriver to unscrew the two 3 mm screws that secure the retaining piece to the hard drive.
Abschluss
Ian Smiley
109 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S4-G3, Valliere Spring 2019 Mitglied von UMass Dartmouth, Team S4-G3, Valliere Spring 2019
UMASSD-VALLIERE-S19S4G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 591
