Einleitung
This guide shows you how to replace your computer’s RAM, this is a short simple process that only requires 1 phillips head screwdriver to complete.
Was du brauchst
Power down the laptop.
Turn the laptop over so the bottom is facing up and the battery is facing towards you.
The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
Slide the left tab to the left and hold it there.
While holding the left tab to the left the battery should easily pull out of the laptop.
Flip the laptop over and locate the hard drive cover. This is a L shaped plastic cover and has 5 PH#1 8mm screws located around the outside edge. The screw locations are denoted by red circles in the figure.
Remove those five screws and then remove the cover.
On either side of the RAM module, there will be two metal tabs. Slide both tabs away from the memory module and the RAM module will pop loose.
