Zum Hauptinhalt wechseln
Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement
Was du brauchst
  1. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Lower Back Panel: Schritt 1, Bild 1 von 3 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Lower Back Panel: Schritt 1, Bild 2 von 3 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Lower Back Panel: Schritt 1, Bild 3 von 3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 2, Bild 1 von 3 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 2, Bild 2 von 3 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 2, Bild 3 von 3
    • Remove four silver screws, highlighted with red circles with a Phillips #1 screwdriver
    • Remove two black screws, highlighted with orange circles with a Phillips #1 screwdriver
  3. Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement: Schritt 3, Bild 1 von 2 Acer Aspire TimelineX 4830T-6682 Hard Disk Drive Replacement: Schritt 3, Bild 2 von 2
    • Pick the hard drive up from the laptop. Keep your hand off the circuit board since the battery is still connected, and voltage might be present
    • Disconnect the SATA connector by pulling the black plastic marked in the pictures horizontally away from the hard drive
Abschluss
Jon Brunsell
592 Reputation
6 Anleitungen geschrieben
IUPUI, Team S1-G1, Beck Spring 2020 Mitglied von IUPUI, Team S1-G1, Beck Spring 2020
IUPUI-BECK-S20S1G1
3 Mitglieder
2 Kommentare
Thanks for the guide. Do you know how to detach the SATA cable from the motherboard? If not, I would really appreciate your help if you know where I should look for an answer. Thanks so much for your help!!
Sasha Maleki - Antwort
Hello,
I am glad you were able to use the guide. The connector is about two centimeters under the cover on the back side of the motherboard. The SATA cable can be removed once the motherboard is detached from the frame.
Best regards,
Jon
Jon Brunsell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 1,119
