Zum Hauptinhalt wechseln
Acer Aspire TimelineX 4830T-6682 RAM Replacement
Was du brauchst
  1. Acer Aspire TimelineX 4830T-6682 RAM Replacement, Lower Back Panel: Schritt 1, Bild 1 von 3 Acer Aspire TimelineX 4830T-6682 RAM Replacement, Lower Back Panel: Schritt 1, Bild 2 von 3 Acer Aspire TimelineX 4830T-6682 RAM Replacement, Lower Back Panel: Schritt 1, Bild 3 von 3
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
  2. Acer Aspire TimelineX 4830T-6682 RAM Replacement, RAM: Schritt 2, Bild 1 von 3 Acer Aspire TimelineX 4830T-6682 RAM Replacement, RAM: Schritt 2, Bild 2 von 3 Acer Aspire TimelineX 4830T-6682 RAM Replacement, RAM: Schritt 2, Bild 3 von 3
    • After the panel has been removed, locate the RAM. It should be on the lower right.
    • There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Erik Bravo
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 436
