Zum Hauptinhalt wechseln
Acer Aspire V3-551-8887 Keyboard Replacement
Was du brauchst
  1. Acer Aspire V3-551-8887 Keyboard Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 2, Bild 1 von 2 Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 Keyboard Replacement, USB Ports: Schritt 3, Bild 1 von 1
    • Locate the wifi chip.
  4. Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 4, Bild 1 von 2 Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  5. Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  6. Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 6, Bild 1 von 2 Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  7. Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 7, Bild 1 von 2 Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  8. Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  9. Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • The USB ports can now be removed from the laptop.
  10. Acer Aspire V3-551-8887 Keyboard Replacement, Keyboard: Schritt 10, Bild 1 von 1
    • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
  11. Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 11, Bild 1 von 2 Acer Aspire V3-551-8887 Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Use a spudger to gently lift the keyboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 8-8, Regan Spring 2014 Mitglied von Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 6,612
