Einleitung
The motherboard is pretty important. Follow this guide to replace yours.
Was du brauchst
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
Use a spudger to pry the panel up from the laptop case and remove it.
The laptop should now be open with the RAM and wifi chip now accessible.
Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
Carefully remove the wifi chip.
Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
Remove the panel and flip it up onto the keyboard
With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
Carefully disconnect the ribbon cable.
Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
Remove the two 10 mm Phillips #1 screws connecting the motherboard to the case.
4 weitere Personen haben diese Anleitung absolviert.
