Zum Hauptinhalt wechseln
Acer Aspire V3-771G Hard Drive Replacement
Was du brauchst
  1. Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Acer Aspire V3-771G Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Shut down the laptop.
    • Remove the power charging cord from the laptop.
  2. Acer Aspire V3-771G Hard Drive Replacement: Schritt 2, Bild 1 von 3 Acer Aspire V3-771G Hard Drive Replacement: Schritt 2, Bild 2 von 3 Acer Aspire V3-771G Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop over, and find the battery compartment.
    • Use your fingers to move the orange slider located just below the battery compartment to the right.
    • Do not touch the battery connectors on the battery or laptop.
    • Lift the battery up and remove from the compartment.
  3. Acer Aspire V3-771G Hard Drive Replacement: Schritt 3, Bild 1 von 2 Acer Aspire V3-771G Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Using the screwdriver, remove the nine 8 mm screws from the panel on the back of the laptop.
    • Gently lift the panel up from the open slot, use the opening tools as necessary, to free the panel from the laptop.
  4. Acer Aspire V3-771G Hard Drive Replacement: Schritt 4, Bild 1 von 2 Acer Aspire V3-771G Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the two screws holding the hard drive sled in place.
    • While grounding yourself, gently pull the black tag straight back, not up, to free the hard drive.
  5. Acer Aspire V3-771G Hard Drive Replacement: Schritt 5, Bild 1 von 3 Acer Aspire V3-771G Hard Drive Replacement: Schritt 5, Bild 2 von 3 Acer Aspire V3-771G Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Using the screwdriver, remove the four 4 mm screws from the hard drive sled.
    • Carefully remove the hard drive. A new one may now be installed.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-36, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-36, Donnelly Fall 2014
USFT-DONNELLY-F14S1G36
1 Mitglied
1 Anleitung geschrieben
Ein Kommentar
Please pardon my inquiry. Is the same replacement can be done to Acer Aspire V3-572P-540V? Any reply will be appreciated.
b6789b - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 33
Insgesamt: 13,652
