Zum Hauptinhalt wechseln
Acer Aspire V5-122P-0468 Network Card Replacement
Was du brauchst
  1. Acer Aspire V5-122P-0468 Network Card Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire V5-122P-0468 Network Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 2, Bild 1 von 2 Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 2, Bild 2 von 2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 3, Bild 1 von 2 Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 3, Bild 2 von 2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 4, Bild 1 von 3 Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 4, Bild 2 von 3 Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 4, Bild 3 von 3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 5, Bild 1 von 3 Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 5, Bild 2 von 3 Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 5, Bild 3 von 3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Network Card Replacement, Network Card: Schritt 6, Bild 1 von 1
    • Remove the wire connector from the network card using a plastic opening tool.
  7. Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 7, Bild 1 von 1
    • Remove the 3mm Phillips #0 screw.
  8. Acer Aspire V5-122P-0468 Network Card Replacement: Schritt 8, Bild 1 von 1
    • Gently slide the network card out of the motherboard connector.
Abschluss
Nat McCormick
801 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S16-G1, Boczar Spring 2018 Mitglied von USF Tampa, Team S16-G1, Boczar Spring 2018
USFT-BOCZAR-S18S16G1
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 537
