Zum Hauptinhalt wechseln
Acer Aspire V5-131-2629 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire V5-131-2629 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Hard Drive Replacement, Cover: Schritt 5, Bild 1 von 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Hard Drive Replacement, Hard Drive: Schritt 7, Bild 1 von 1
    • Locate the large blue hard drive on the left side on the computer.
  8. Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Gently pull out the ribbon cable on the computer-attached end.
  9. Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Completely remove the hard drive from the hard drive bay.
  10. Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 10, Bild 1 von 2 Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 10, Bild 2 von 2
    • Remove the two screws on the side of the hard drive cage.
  11. Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 11, Bild 1 von 2 Acer Aspire V5-131-2629 Hard Drive Replacement: Schritt 11, Bild 2 von 2
    • Pull the hard drive cage from the hard drive to separate the two.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 1,371
