Zum Hauptinhalt wechseln
Acer Aspire V5-131-2629 RAM Replacement
Was du brauchst
  1. Acer Aspire V5-131-2629 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 RAM Replacement: Schritt 2, Bild 1 von 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 RAM Replacement: Schritt 3, Bild 1 von 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 RAM Replacement: Schritt 4, Bild 1 von 2 Acer Aspire V5-131-2629 RAM Replacement: Schritt 4, Bild 2 von 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 RAM Replacement, Cover: Schritt 5, Bild 1 von 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 RAM Replacement: Schritt 6, Bild 1 von 2 Acer Aspire V5-131-2629 RAM Replacement: Schritt 6, Bild 2 von 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 RAM Replacement, RAM: Schritt 7, Bild 1 von 1
    • Using your finger, press the small tab on each side of the memory card.
    • The memory card will eject at a 45 degree angle.
  8. Acer Aspire V5-131-2629 RAM Replacement: Schritt 8, Bild 1 von 1
    • Pull the memory cards out from the laptop.
Abschluss
Nicholas Vassiliadis
85 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 567
