Zum Hauptinhalt wechseln
Acer Aspire V5-131-2629 Screen Replacement
Was du brauchst
  1. Acer Aspire V5-131-2629 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Screen Replacement: Schritt 2, Bild 1 von 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Screen Replacement: Schritt 3, Bild 1 von 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Screen Replacement: Schritt 4, Bild 1 von 2 Acer Aspire V5-131-2629 Screen Replacement: Schritt 4, Bild 2 von 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Screen Replacement, Cover: Schritt 5, Bild 1 von 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Screen Replacement: Schritt 6, Bild 1 von 2 Acer Aspire V5-131-2629 Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the cover by sliding it outwards and remove it from the device.
  7. Acer Aspire V5-131-2629 Screen Replacement, Screen: Schritt 7, Bild 1 von 2 Acer Aspire V5-131-2629 Screen Replacement, Screen: Schritt 7, Bild 2 von 2
    • Remove the screen bezel by lifting up the inside rim of the bezel and popping the edge out in steady upwards and outwards motions.
    • Complete this motion around the entire circumference of the bezel.
  8. Acer Aspire V5-131-2629 Screen Replacement: Schritt 8, Bild 1 von 3 Acer Aspire V5-131-2629 Screen Replacement: Schritt 8, Bild 2 von 3 Acer Aspire V5-131-2629 Screen Replacement: Schritt 8, Bild 3 von 3
    • Remove the four Phillips screws from each of the mounting tabs in the corners of the screen.
  9. Acer Aspire V5-131-2629 Screen Replacement: Schritt 9, Bild 1 von 1
    • Peel back the adhesive tape that runs the length of the bottom of the screen.
    • Be careful not to damage the cables which run between the tape and the screen.
  10. Acer Aspire V5-131-2629 Screen Replacement: Schritt 10, Bild 1 von 1
    • Using the mounting tabs at the top corners of the screen, gently lift the screen up and out and lay it flat on the keyboard.
  11. Acer Aspire V5-131-2629 Screen Replacement: Schritt 11, Bild 1 von 1
    • Remove the adhesive tape covering the gold-colored connector on the top left corner of the screen.
Abschluss
UMass Dartmouth, Team S1-G3, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G3, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G3
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 28
Insgesamt: 702
