Zum Hauptinhalt wechseln
Acer Aspire V5-131-2680 Battery Replacement
Was du brauchst
  1. Acer Aspire V5-131-2680 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Battery Replacement: Schritt 2, Bild 1 von 2 Acer Aspire V5-131-2680 Battery Replacement: Schritt 2, Bild 2 von 2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Battery Replacement: Schritt 3, Bild 1 von 2 Acer Aspire V5-131-2680 Battery Replacement: Schritt 3, Bild 2 von 2
    • In front of the battery, you will find a sliding flap. This is a battery-release lock.
    • Place your finger on the latch and slide the latch to open. Pull out the battery from its compartment.
    • Do not remove your finger from the latch while sliding the battery out.
    • Once the battery is out, release the latch.
Abschluss
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 192
