Zum Hauptinhalt wechseln
Acer Aspire V5-131-2680 Motherboard Replacement
Was du brauchst
  1. Acer Aspire V5-131-2680 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Turn the Acer Aspire upside down, with the stickers facing up.
    • Unplug the charger and make sure the device is off.
  2. Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the twenty M2 x 6 screws using a Phillips #00 screwdriver.
    • Unplug the battery and disconnect all the components connected to the motherboard.
    • Pry open the bottom of the laptop using the opening tool.
  3. Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 3, Bild 1 von 3 Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 3, Bild 2 von 3 Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the two components that are attached to the motherboard and keyboard.
    • The large ribbon cable is disconnected by pulling apart the two white tabs found on each side of the connection and lifting the cable out.
    • The small wire can be removed by simply pulling on the blue tape
  4. Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the three M2 x 3 Phillips screws on the motherboard.
  5. Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 5, Bild 1 von 3 Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 5, Bild 2 von 3 Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Disconnect all the big and small wires connected to the motherboard.
    • The big wires must be squeezed on each side of the connection to release the tabs, then pull the cable out.
    • The small wires can be removed simply by pulling the cable out of the connection
  6. Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Gently pull the motherboard up and to the right at the same time.
  7. Acer Aspire V5-131-2680 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Once the motherboard is out, take off the tape that is holding the fan and the motherboard together. Push the fan down and it will come off.
Abschluss
Mauricio Moreno
601 Reputation
5 Anleitungen geschrieben
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 223
