Zum Hauptinhalt wechseln
Acer Aspire V5-131-2680 Screen Replacement
Was du brauchst
  1. Acer Aspire V5-131-2680 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Open up your laptop.
    • Place an opening tool in the crack between the screen and the back compartment. Drag the opening tool throughout the crack to open.
    • Remove the front black frame of the laptop.
  2. Acer Aspire V5-131-2680 Screen Replacement: Schritt 2, Bild 1 von 1
    • Use a JIS #1 screwdriver to remove the 10 marked M2 x 3 Phillips screws.
    • Use a magnetic bit to fully remove the screws from their locations.
  3. Acer Aspire V5-131-2680 Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove then aluminum frame holding the screen in place.
    • This frame may have some sharp edges. Lift and remove slowly.
  4. Acer Aspire V5-131-2680 Screen Replacement: Schritt 4, Bild 1 von 1
    • Carefully peel off the tape surrounding the screen.
  5. Acer Aspire V5-131-2680 Screen Replacement: Schritt 5, Bild 1 von 1
    • Unplug the pin conector from the display.
    • This is a sensitive piece. Do not grab harshly or the pin can break.
    • The screen is now free to be removed.
Abschluss
Mauricio Moreno
601 Reputation
5 Anleitungen geschrieben
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 106
