Zum Hauptinhalt wechseln
Acer Aspire V5-131-2680 Touchpad Replacement
Was du brauchst
  1. Acer Aspire V5-131-2680 Touchpad Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Touchpad Replacement: Schritt 2, Bild 1 von 2 Acer Aspire V5-131-2680 Touchpad Replacement: Schritt 2, Bild 2 von 2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Touchpad Replacement, Touchpad: Schritt 3, Bild 1 von 1
    • Unscrew the twenty M2 x 6 Phillips screws using a #00 Phillips screwdriver and a PH001 bit. Then, unplug the battery and disconnect all the components connected to the motherboard.
    • Pry open the bottom of the laptop using the pry tool.
  4. Acer Aspire V5-131-2680 Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the larger ribbon cable that connects from the motherboard to the keyboard by gently pulling on the end that attaches to the keyboard.
  5. Acer Aspire V5-131-2680 Touchpad Replacement: Schritt 5, Bild 1 von 1
    • Remove the tape that is holding the smaller ribbon to the touchpad. Gently disconnect the smaller ribbon by pulling on it.
  6. Acer Aspire V5-131-2680 Touchpad Replacement: Schritt 6, Bild 1 von 1
    • Once both of the ribbons are disconnected, the side with the keyboard will detach from the rest of the computer.
    • Now we can move the keyboard side without the rest of the laptop.
  7. Acer Aspire V5-131-2680 Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Remove all of the M2 x 3 Phillips screws that are holding the keyboard in place.
    • Some screws will be located under a piece of tape. Remove the tape prior to unscrewing these screws.
  8. Acer Aspire V5-131-2680 Touchpad Replacement: Schritt 8, Bild 1 von 1
    • Remove the keyboard from the frame by pulling up on the keyboard.
    • With the keyboard out of the way, we will be able to access the touchpad.
  9. Acer Aspire V5-131-2680 Touchpad Replacement: Schritt 9, Bild 1 von 2 Acer Aspire V5-131-2680 Touchpad Replacement: Schritt 9, Bild 2 von 2
    • Remove the touchpad from the frame by pushing up on the touchpad.
Abschluss
Mauricio Moreno
601 Reputation
5 Anleitungen geschrieben
CSU Los Angeles, Team 6-1, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 6-1, Adachi Fall 2022
CSULA-ADACHI-F22S6G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 162
