Zum Hauptinhalt wechseln
Acer Aspire V5-473P-5602 Touchpad Replacement
Was du brauchst
  1. Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: Schritt 2, Bild 1 von 2 Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: Schritt 2, Bild 2 von 2
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Touchpad Replacement, Touchpad: Schritt 5, Bild 1 von 1
    • Use a spudger to remove the aluminum foil tape from the touchpad.
  6. Acer Aspire V5-473P-5602 Touchpad Replacement: Schritt 6, Bild 1 von 1
    • Unplug the cable from the touchpad.
  7. Acer Aspire V5-473P-5602 Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Remove ten Phillips #0 screws securing the touchpad to the base.
  8. Acer Aspire V5-473P-5602 Touchpad Replacement: Schritt 8, Bild 1 von 1
    • Use the pointed end of a spudger to remove the small triangular metal piece.
  9. Acer Aspire V5-473P-5602 Touchpad Replacement: Schritt 9, Bild 1 von 2 Acer Aspire V5-473P-5602 Touchpad Replacement: Schritt 9, Bild 2 von 2
    • Use the spudger to lift up the touchpad carefully.
    • Remember to use electronic cleaner to clean the touchpad screen surface before placing the new touchpad back in.
Abschluss
Thuy Tran
267 Reputation
2 Anleitungen geschrieben
York University, Team S8-G6, Turner Winter 2020 Mitglied von York University, Team S8-G6, Turner Winter 2020
YORK-TURNER-W20S8G6
5 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 337
