Einleitung
This guide will show you how to replace the hard drive of your Acer Aspire V5-552PG-X469 laptop.
Was du brauchst
Use a Phillips #0 screwdriver to remove seventeen 7mm screws from the lower case.
First locate the the hard drive as outlined
Pull the black bundle cable from its slot by its purple tab
Finally, lift and remove the hard drive
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
