Einleitung
How to replace the CMOS / BIOS Battery
____________________________________________________________________
Was du brauchst
Einführungsvideo
Turn off the laptop and remove the battery.
Remove two screws securing the Keyboard.
The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
Remove the Keyboard and disconnect the two flex cables:
Keyboard flex cable
Keyboard Light flex cable
Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
Slide the drive to the left and remove it.
Remove 4x phillips screws and disconnect:
Power On button flex cable
Touch pad flex cable
Remove 18x Phillips screws from the bottom cover.
Remove any memory SD Card from the Card reader.
Start opening with a plastic opening tool.
Gently remove the HDD and disconnect the SATA cable from it.
Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
Remove the Wi-Fi card.
Remove the Memory Cover.
Disconnect the Loudspeaker cable connector.
Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
Disconnect the LCD Display flex cable.
Disconnect the DC Jack cable.
Carefully remove the Optical drive SATA adapter.
We will disconnect the battery cable when we pick up the board.
Use sharp plastic tool and remove the CMOS Battery.
CR2032 - button cell lithium battery rated at 3.0 volts.
Did you do it successfully?
7 weitere Personen haben diese Anleitung absolviert.
7 Kommentare
I need assistance with the G2201 Hardware Gap, Im attempting to remove a HHD password for a customers machine on this same model
I have same problem with same mother board please help me
