Einleitung
How to replace or upgrade the Hard Drive.
Please SUBSCRIBE to my channel ツ
Einführungsvideo
  1. Turn off the laptop and remove the battery. Remove two screws securing the Keyboard. The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Remove the Keyboard and disconnect the two flex cables: Keyboard flex cable Keyboard Light flex cable
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove 4x phillips screws and disconnect: Power On button flex cable Touch pad flex cable
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Carefully separate the upper cover and remove it. Carefully separate the upper cover and remove it. Carefully separate the upper cover and remove it.
    • Carefully separate the upper cover and remove it.
  6. Gently remove the HDD and disconnect the SATA cable from it. Please SUBSCRIBE to my channel  ツ Please SUBSCRIBE to my channel  ツ
Abschluss
23 weitere Nutzer haben diese Anleitung absolviert.
ZFix
163.017 Reputation
304 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
281 Mitglieder
792 Anleitungen geschrieben
Good job! What a pain, though, to swap the HDD :)
Steve Wojciechowski - Antwort
I am currently working on this laptop and it doesn't open at all like this one. This is only one back... and 18 screws holding it on. I can partially snap the back off but i can't pry it apart by the dvd drive. I'm also guessing the same model is manufactured differently for different retailers. (This happens in the retail hardware world where a dewalt drill from home depot will be made cheaper than a dewalt from ace hardware) so now I"m stuck. any ideas would be helpful. thanks.
FallenAnjel - Antwort
ok found the problem. i accidentally popped out the dvd drive (when I was just trying to open it lol) and up under the lip I found three 1/8" long very-flat head screws. unscrewed those and the back came right off.
New customer that does like shopping local with recommended proprietors and stockiest of the required components.
Thank you Mr Jason Paul Cominelli.
Jason Paul Cominelli - Antwort
are 9mm hard disk can fit?
the original was 7mm
jason.chiah1008 - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 15
Letzte 7 Tage: 159
Letzte 30 Tage: 680
Insgesamt: 51,582
