Zum Hauptinhalt wechseln
Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement
Was du brauchst
Einführungsvideo
  1. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Keyboard: Schritt 1, Bild 1 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Keyboard: Schritt 1, Bild 2 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: Schritt 2, Bild 1 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: Schritt 2, Bild 2 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: Schritt 2, Bild 3 von 3
  3. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Upper  Cover: Schritt 3, Bild 1 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Upper  Cover: Schritt 3, Bild 2 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, Upper  Cover: Schritt 3, Bild 3 von 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  4. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: Schritt 4, Bild 1 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: Schritt 4, Bild 2 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement: Schritt 4, Bild 3 von 3
    • Carefully separate the upper cover and remove it.
  5. Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): Schritt 5, Bild 1 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): Schritt 5, Bild 2 von 3 Acer Aspire V5-571 HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): Schritt 5, Bild 3 von 3
Abschluss
32 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.368 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.468 Anleitungen geschrieben
6 Kommentare
Good job! What a pain, though, to swap the HDD :)
Steve Wojciechowski - Antwort
I am currently working on this laptop and it doesn't open at all like this one. This is only one back... and 18 screws holding it on. I can partially snap the back off but i can't pry it apart by the dvd drive. I'm also guessing the same model is manufactured differently for different retailers. (This happens in the retail hardware world where a dewalt drill from home depot will be made cheaper than a dewalt from ace hardware) so now I"m stuck. any ideas would be helpful. thanks.
FallenAnjel - Antwort
ok found the problem. i accidentally popped out the dvd drive (when I was just trying to open it lol) and up under the lip I found three 1/8" long very-flat head screws. unscrewed those and the back came right off.
New customer that does like shopping local with recommended proprietors and stockiest of the required components.
Thank you Mr Jason Paul Cominelli.
Jason Paul Cominelli - Antwort
are 9mm hard disk can fit?
the original was 7mm
jason.chiah1008 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 18
Letzte 30 Tage: 88
Insgesamt: 69,572
