Zum Hauptinhalt wechseln
Acer Aspire V5-571 Optical Drive Replacement
Was du brauchst
Einführungsvideo
  1. Acer Aspire V5-571 Optical Drive Replacement, Keyboard: Schritt 1, Bild 1 von 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: Schritt 1, Bild 2 von 3 Acer Aspire V5-571 Optical Drive Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Optical Drive Replacement: Schritt 2, Bild 1 von 3 Acer Aspire V5-571 Optical Drive Replacement: Schritt 2, Bild 2 von 3 Acer Aspire V5-571 Optical Drive Replacement: Schritt 2, Bild 3 von 3
  3. Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 2 von 3 Acer Aspire V5-571 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 3 von 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.182 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.521 Anleitungen geschrieben
2 Kommentare
Is it safe to use with the optical drive out? I just took it out and I don't get the part until next week but I need to use my laptop... can I use it?
I needed to replace it because I dropped my laptop off the arm of the sofa with the drive open and falling on that side too.
Vianca - Antwort
Is it safe to use the laptop with the optical drive out?
Vianca - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 5,115
