Einleitung
Acer Aspire V5-571 - How to remove the Upper Cover.
  1. Turn off the laptop and remove the battery. Remove two screws securing the Keyboard. The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Remove the Keyboard and disconnect the two flex cables: Keyboard flex cable Keyboard Light flex cable
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic. Slide the drive to the left and remove it. Slide the drive to the left and remove it.
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  5. Remove 4x phillips screws and disconnect: Power On button flex cable Touch pad flex cable
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  6. Carefully separate the upper cover and remove it. Carefully separate the upper cover and remove it. Carefully separate the upper cover and remove it.
    • Carefully separate the upper cover and remove it.
Abschluss
ZFix
162.332 Reputation
304 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
280 Mitglieder
783 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 1,944
