Zum Hauptinhalt wechseln
Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement
Was du brauchst
  1. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
  2. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 2, Bild 1 von 2 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 2, Bild 2 von 2
    • Slide the battery out of the battery slot.
  3. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • Remove the two 6mm PH1 screws from the bottom of the laptop.
  4. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 4, Bild 1 von 1
    • Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
    • Do this with the computer slightly open for ease.
  5. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 5, Bild 1 von 2 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 5, Bild 2 von 2
    • Open the laptop.
    • Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
    • The keyboard can be flipped onto its face once removed.
  6. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 6, Bild 1 von 1
    • Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
  7. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the keyboard by pulling the blue tape on the wire strip.
  8. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement, Hard Disk Drive (HDD): Schritt 8, Bild 1 von 1
    • Remove the five 6mm PH1 screws beneath the keyboard.
  9. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 9, Bild 1 von 2 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 9, Bild 2 von 2
    • Use the spudger to pop the gray tab up and away from the far left wire strip.
    • Disconnect the wire strip by pulling the blue tab loose.
  10. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 10, Bild 1 von 2 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 10, Bild 2 von 2
    • Use the spudger to pop the white tab up away from the wire strip located at the top left corner of the mouse pad.
    • Disconnect the wire strip by pulling the blue tab.
  11. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 11, Bild 1 von 1
    • Close the laptop.
    • Remove the remaining 18 6mm PH1 screws from the bottom cover of the laptop.
  12. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 12, Bild 1 von 3 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 12, Bild 2 von 3 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 12, Bild 3 von 3
    • Use the opening tool to separate the back of the laptop from the inside cover.
    • Open the computer and remove the inside cover.
  13. Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 13, Bild 1 von 3 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 13, Bild 2 von 3 Acer Aspire V5-571-6891 Hard Disk Drive (HDD) Replacement: Schritt 13, Bild 3 von 3
    • Lift the HDD out of the base and use the opening tool to disconnect the HDD from the motherboard wire.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 715
