Einleitung
The keyboard may be easily replaced if a key or keys no longer works. It is accessible without removing the back cover of the computer.
Was du brauchst
Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
Use the spudger, push the two tabs, located in the battery slot, through their slots to release the keyboard.
Do this with the computer slightly open for ease.
Open the laptop.
Start top of the keyboard and use the opening tool to pop the remaining tabs around the keyboard loose.
The keyboard can be flipped onto its face once removed.
Use the spudger and slide the grey tabs on either side of the keyboard wires away from the white plastic.
2 weitere Personen haben diese Anleitung absolviert.
