Einleitung
The RAM may be responsible for slow or non-existent memory. This guide shows how to replace the RAM.
  1. Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
    • Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
  2. Slide the battery out of the battery slot.
    • Slide the battery out of the battery slot.
    • Unscrew the two RAM 6mm cover screws.
    • Use a PH1 screw bit.
    • Pop the RAM cover off.
    • Use the plastic opening tool.
    • Use either the spudger or your fingers to pinch the clips away from the RAM chip on either side of each chip.
      • The chip should pop up.
      • The clips break easily.
    • Slide the RAM memory chips out of the slots.
Abschluss
Lakbira Sheffield
Mitglied seit 29.01.2018
583 Reputation
4 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 54
