Einleitung
The RAM may be responsible for slow or non-existent memory. This guide shows how to replace the RAM.
Was du brauchst
Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
Use either the spudger or your fingers to pinch the clips away from the RAM chip on either side of each chip.
The chip should pop up.
Slide the RAM memory chips out of the slots.
