Einleitung
How to disassemble the laptop and change the Cooling system.
Was du brauchst
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Disconnect the Fan cable.
Remove the three screws from the CPU cooler and one from the Fan module.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
