Einleitung
Acer Aspire - V5-572, V5-572G
Follow this guide if you want to change / upgrade your HDD (Hard Disk Drive) or install SSD (Solid State Drive).
Was du brauchst
Einführungsvideo
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Disconnect the SATA Cable from the Mother Board.
Take out the HDD and remove the SATA cable from it.
Now you can change / upgrade your HDD.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
ashmir, you just clone your HDD with a free software such as Macrium Reflect and don’t need to worry about installing everything from zero!!!
Thank you for the tutorial.
But need a clarification. If i have a faulty hard disc it starts up but it freezes after 20 minutes.
Is it still possible to clone it.
Also if i change the hard drive do I need to install any software or the bios all over again.
Your inputs will be appreciated.
