Einleitung
Acer Aspire - V5-572, V5-572G
How to disassemble the Laptop and change the Loudspeaker modules.
Was du brauchst
Einführungsvideo
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
Disconnect the Loudspeakers cable.
There are two modules with loudspeakers, connected with one wire.
Unscrew the screws and remove the Loudspeaker modules together with the cable.
Eine weitere Person hat diese Anleitung absolviert.
