Einleitung
Acer Aspire - V5-572, V5-572G
We will show you how to open the Laptop and install a new RAM Module.
Was du brauchst
Einführungsvideo
Starting from the SD Memory Card hole, start prying between the top and bottom cases.
Remove the bottom case.
This model have 1x Memory Slot.
You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
