Einleitung
Acer Aspire - V5-572, V5-572G
We will show you how to open the Laptop and install a new RAM Module.
Einführungsvideo
  1. Switch-off the Laptop. Remove 17x Philips screws.
    • Switch-off the Laptop.
    • Remove 17x Philips screws.
  2. Start opening from the SD Memory Card hole Use plastic tools to avoid damaging the cover. Use plastic tools to avoid damaging the cover.
    • Start opening from the SD Memory Card hole
    • Use plastic tools to avoid damaging the cover.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Before doing anything, disconnect the battery.
    • Before doing anything, disconnect the battery.
  5. This model have 1x Memory Slot. You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600. You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
    • This model have 1x Memory Slot.
    • You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
ZFix
162.404 Reputation
304 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
280 Mitglieder
783 Anleitungen geschrieben
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 5
Letzte 7 Tage: 42
Letzte 30 Tage: 187
Insgesamt: 13,721
