Zum Hauptinhalt wechseln
Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade
Was du brauchst
Einführungsvideo
  1. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Bottom Cover: Schritt 1, Bild 1 von 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: Schritt 2, Bild 1 von 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: Schritt 3, Bild 1 von 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: Schritt 3, Bild 2 von 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: Schritt 3, Bild 3 von 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade: Schritt 4, Bild 1 von 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): Schritt 5, Bild 1 von 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): Schritt 5, Bild 2 von 3 Acer Aspire V5-572, V5-572G Memory (RAM) Upgrade, Memory (RAM): Schritt 5, Bild 3 von 3
    • This model have 1x Memory Slot.
    • You can upgrade your laptop with SODIMM DDR3 ram at 1333 or 1600.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
ZFix
194.021 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
327 Mitglieder
1.697 Anleitungen geschrieben
Ein Kommentar
Hi,
While adding an extra RAM to the module in Aspire V5-472, I forgot to disconnnect the battery first.
I first tried 4 GB RAM compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. When that didn't work, I checked again.
Next time I disconnected the battery, and repeated the process with 2 GB RAM, compatible, SODIMMM- DDR3L 204-Pin Laptop Memory, Low Voltage. The RAM was still not discovered. None of the RAMs were detected.
Hope I haven't fried the RAM Module itself.
Please help.
Indi Shukla - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 24
Letzte 30 Tage: 79
Insgesamt: 23,634
