Zum Hauptinhalt wechseln
Acer Aspire V5-591G-75KE Laptop Battery Replacement
Was du brauchst
  1. Acer Aspire V5-591G-75KE Laptop Battery Replacement, Acer Aspire V5-591G-75KE Disassembly: Schritt 1, Bild 1 von 3 Acer Aspire V5-591G-75KE Laptop Battery Replacement, Acer Aspire V5-591G-75KE Disassembly: Schritt 1, Bild 2 von 3 Acer Aspire V5-591G-75KE Laptop Battery Replacement, Acer Aspire V5-591G-75KE Disassembly: Schritt 1, Bild 3 von 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Laptop Battery Replacement: Schritt 2, Bild 1 von 2 Acer Aspire V5-591G-75KE Laptop Battery Replacement: Schritt 2, Bild 2 von 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Laptop Battery Replacement: Schritt 3, Bild 1 von 2 Acer Aspire V5-591G-75KE Laptop Battery Replacement: Schritt 3, Bild 2 von 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Laptop Battery Replacement: Schritt 4, Bild 1 von 3 Acer Aspire V5-591G-75KE Laptop Battery Replacement: Schritt 4, Bild 2 von 3 Acer Aspire V5-591G-75KE Laptop Battery Replacement: Schritt 4, Bild 3 von 3
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Laptop Battery Replacement, Laptop Battery: Schritt 5, Bild 1 von 2 Acer Aspire V5-591G-75KE Laptop Battery Replacement, Laptop Battery: Schritt 5, Bild 2 von 2
    • The laptop battery is the black rectangular item at the top.
    • The battery connects to the motherboard via a multi-colored 8-pin connector.
    • Using a pair of blunt tweezers, push the white tabs on the sides 8-pin connector to disconnect the battery from the motherboard.
  6. Acer Aspire V5-591G-75KE Laptop Battery Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery directly up to remove it from the laptop. It is not screwed on.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Tasier Hagler
428 Reputation
4 Anleitungen geschrieben
UW Tacoma, Team S3-G5, Liner Fall 2017 Mitglied von UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 2,218
