Einleitung
Do not proceed with this guide unless you are prepared to clean and re-apply thermal compound. For more information, please refer to the How to Clean and Apply Thermal Compound guide.
Was du brauchst
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
With the screws removed, flip the device right-side up and open up the display.
Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
Using the plastic tabs, lift the hard drive slightly and pull to the left.
Remove the rubber mounting brackets from the hard drive.
Locate the memory modules at the bottom right quadrant of the motherboard. The two memory modules are slightly stacked on top of each other.
Using both hands, pull the clasps away simultaneously in order to release the memory modules.
To remove the top memory module, lift the module slightly up and pull away.
Repeat the previous step to remove the bottom memory module.
Locate the wireless card on the top left quadrant. It should have two antenna cables connected to it, one white and one black.
With a pair of blunt tweezers, firmly grasp each antenna head and detach it by lifting straight up.
Using a Phillip Head size 1 screwdriver, remove the screw attaching the wireless card to the laptop frame.
To detach the wireless card, lift up slightly and pull away.
Use a Phillips Head size #1 screwdriver to remove the two silver-colored 10mm Phillips Head screws securing the fan to the motherboard.
Use a pair of blunt tweezers to gently push on the 3-pin connector. This disconnects the fan from the motherboard.
Use a Phillips #1 screwdriver to remove 6 black 10mm Phillips Head screws that connect the copper heat-sink to the motherboard.
Using both hands, gently lift the heat-sink and fan components from the motherboard.
With all major components removed, proceed to locate the connectors marked on the photograph:
Power jack harness connector.
Ribbon cables.
Display cable connector.
Keyboard connector.
Disconnect the power jack harness from the motherboard by pushing on the tabs with a pair of blunt tweezers.
Use a plastic opening tool to pry open the locks, then pull the ribbon cables out.
The ribbon cables have small locks securing them in place.
Use a plastic opening tool to pry the locks up. Once unlocked, simply pull the cables out.
The display cable connects the motherboard to your laptop's monitor. It has a small tab lock on it.
Use a plastic opening tool to pry the tab lock up.
Use the plastic ears on top of the cable to head to disconnect the display cable from the motherboard.
To disconnect the wide ribbon cable, use your fingers to pull back the black tab until it is loose.
Slide out the black plastic tab from beneath the ribbon cable.
Once the plastic tab is out, simply pull out the wide ribbon cable.
Use a Phillips #1 screwdriver to remove the 3 black 10mm Phillips Head screws securing the motherboard to the face-plate of the device.
Lift the motherboard gently to completely remove this component from the device.
You can follow the steps in reverse to reassemble your device, but you should not re-seat the heat sink and fan without cleaning and re-applying the thermal compound.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Is it necessary to remove everything especially heat sink if I want to replace only keyboard?
