Einleitung
This guide will help you identify, remove, and potentially replace the power jack harness within the Acer Aspire V5-591G-75KE.
Was du brauchst
Close down the display and flip the device upside down.
Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
With the screws removed, flip the device right-side up and open up the display.
Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
Locate the power jack harness on the upper left quadrant of your device.
Note where the power jack harness connects to the mother board of your device.
With a pair of blunt tweezers, push on the side tabs of the connector to disconnect the harness from the motherboard.
Using a Phillips #1 screwdriver, remove the single 10mm Phillips Head screw located on the hinge.
Wedge the spudger tool below the hinge, and lift only enough to get a grip with your fingers.
Wedge the spudger tool below the port harness head, and lift straight up until the side tabs clear the channels on each side.
Lift to completely remove the rest of the power jack harness out of the casing.
Eine weitere Person hat diese Anleitung absolviert.
3 Kommentare
Okay, so I did fix this… But after we booted up the sound stopped working. I was very careful, but maybe knocked something? Any suggestions much appreciated.
Thank you
Check the step where you open the case. There is a cable you need to remove thats holding the case to the laptop. Just link that back to where it was and it should work
hrstg -
