Zum Hauptinhalt wechseln
Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement
Was du brauchst
  1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: Schritt 1, Bild 1 von 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: Schritt 1, Bild 2 von 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: Schritt 3, Bild 1 von 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: Schritt 4, Bild 1 von 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery.
  6. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: Schritt 6, Bild 1 von 2 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: Schritt 6, Bild 2 von 2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: Schritt 7, Bild 1 von 3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: Schritt 7, Bild 2 von 3 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: Schritt 7, Bild 3 von 3
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
Abschluss
USF Tampa, Team S15-G4, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 178
