Zum Hauptinhalt wechseln
Acer C933 Hinge Replacement
Was du brauchst
    1. Acer C933 Hinge Replacement, Hinge: Schritt 1, Bild 1 von 2 Acer C933 Hinge Replacement, Hinge: Schritt 1, Bild 2 von 2
      • Make sure to power off the device and keep it off for the duration of the procedure.
      • Use a Phillips #00 screwdriver to remove the ten 3 mm screws from the bottom panel.
      • Use an opening tool or spudger to release the clips securing the bottom case.
      • Remove the bottom panel.
      Frag FixBot
      Kommentar hinzufügen
    2. Acer C933 Hinge Replacement: Schritt 2, Bild 1 von 3 Acer C933 Hinge Replacement: Schritt 2, Bild 2 von 3 Acer C933 Hinge Replacement: Schritt 2, Bild 3 von 3
      • Handle ALL components with care!
      • Zero Insertion Force(ZIF) connecters are commonly used to secure delicate cables. A lock hinge flap secures the cable in place and protects it.
      • To disconnect the display screen cable, use a clean finger nail to flip up the flap to unlock its position. Carefully use tweezers of clean fingers to pull the display screen cable out.
      • Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the Wi-Fi connector (as close to the head as possible) and lift straight up from the board.
      • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
      • Note which cord goes where for reassembly! Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
      • Use a Phillips #00 screwdriver to remove the 3 mm screws securing the each hinge set to the chassis. Remove the display assembly.
      • Keep the screws for reassembly.
      Frag FixBot
    3. Acer C933 Hinge Replacement: Schritt 3, Bild 1 von 2 Acer C933 Hinge Replacement: Schritt 3, Bild 2 von 2
      • Gently insert a spudger under the bezel and release the clips to remove it from the screen.
      • The bezel can easily crack or break so be careful when removing it.
      Frag FixBot
    4. Acer C933 Hinge Replacement: Schritt 4, Bild 1 von 3 Acer C933 Hinge Replacement: Schritt 4, Bild 2 von 3 Acer C933 Hinge Replacement: Schritt 4, Bild 3 von 3
      • Use a Phillips #00 screwdriver to remove the 3 mm screws holding the hinge set to the display assembly.
      • Keep screws placed on the side accordingly.
      • Use a Phillips #00 screwdriver to remove the 2.5 mm screws holding the screen in place.
      • Remove the screen.
      Frag FixBot
    5. Acer C933 Hinge Replacement: Schritt 5, Bild 1 von 2 Acer C933 Hinge Replacement: Schritt 5, Bild 2 von 2
      • Turn the screen around and remove a hinge set from each side.
      • Put the new hinge set in place and press down.
      • Upon completing this step, you have now successfully replaced your hinge and need to reassemble your device.
      Frag FixBot
Abschluss
To reassemble your device, follow the instructions one through five in reverse order.
ricky
121 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 3-2, Grodsky Spring 2025 Mitglied von CSU Los Angeles, Team 3-2, Grodsky Spring 2025
CSULA-GRODSKY-S25S3G2
1 Mitglied
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 379
