Zum Hauptinhalt wechseln
Acer Chromebook 13 CB5-311-T7NN Battery Replacement
Was du brauchst
  1. Acer Chromebook 13 CB5-311-T7NN Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the computer over and use a Phillips #0 screwdriver head to remove the 13 2.5 mm bottom cover screws.
  2. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: Schritt 2, Bild 1 von 1
    • Use your spudger to carefully pry the bottom cover away from the palm rest assembly.
    • Don't pull the cover away too hard once it's apart from the assembly because the headphone jack cable is still attached to the bottom cover.
  3. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: Schritt 3, Bild 1 von 1
    • Use the pointed side of the spudger to disconnect the headphone jack cable from the motherboard and completely remove the bottom cover.
  4. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: Schritt 4, Bild 1 von 1
    • Use the pointed side of the spudger to disconnect the battery cable from the motherboard.
  5. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook 13 CB5-311-T7NN Battery Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #0 screwdriver head to remove the two 2.5 mm #1 battery screws.
    • Use your hands to remove the battery by gently picking it up.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 1,623
