Zum Hauptinhalt wechseln
Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement
Was du brauchst
  1. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: Schritt 3, Bild 2 von 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Lift off the back cover.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 678
