Zum Hauptinhalt wechseln
Acer Chromebook 14 CB3-431-C7EX Battery Replacement
Was du brauchst
  1. Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • There are several clips holding the cover in place.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
    Frag FixBot
    Kommentar hinzufügen
  2. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to disconnect the battery's connector from the motherboard. The connector should slide out toward the battery.
    • Be sure to remove the connector evenly from the port.
    Frag FixBot
  3. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook 14 CB3-431-C7EX Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #0 screwdriver to unscrew the two 5.5mm screws from the battery housing.
    Frag FixBot
  4. Acer Chromebook 14 CB3-431-C7EX Battery Replacement: Schritt 4, Bild 1 von 1
    • While lifting the connector side of the battery, slide the battery towards the center of the laptop.
    • Be mindful of the tabs on the bottom of the battery housing (shown in picture). These need to be underneath slots when reinserting the battery back into the laptop.
    • Remove the battery from the laptop.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
clear and concise
good instructions
battery can be found for less than half that cost online
mapatouli - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 2,886
