Zum Hauptinhalt wechseln
Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement
Was du brauchst
  1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 2 von 3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • Use a spudger to carefully disconnect the ribbon connector from the right side of the sound card. The connector should slide out toward the motherboard.
    • Be sure to remove the connector evenly from the port, as the ribbon connector may be fragile.
  4. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
  5. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Slide the sound card towards the motherboard until the headphone jack is out of its hole on the side of the laptop.
    • Lift the sound card directly up from the laptop to remove it.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 627
