Zum Hauptinhalt wechseln
Acer Chromebook 15 C910-C453 Battery Replacement
Was du brauchst
  1. Acer Chromebook 15 C910-C453 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Chromebook 15 C910-C453 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Battery Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook 15 C910-C453 Battery Replacement: Schritt 3, Bild 2 von 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Battery Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook 15 C910-C453 Battery Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S15-G1, Banghart Spring 2017 Mitglied von Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Jacob, WELL DONE. I have an Acer 15 C910-C451 that was driving me nuts. It would hold a battery charge but only up to 17% then drain fairly rapidly duing use. It didn’t make sense that a battery would have a set of bad cells but that is probably exactly what was the problem. So new battery in hand and a set of tools designed not to harm the case I followed your instructions to the letter. BINGO ! At this moment the unit is charging from a start of 87% it is now at 96% and climbing. Thanks for the detailed pics of the process.
Thomas Revell - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 10,278
