Zum Hauptinhalt wechseln
Acer Chromebook 15 C910-C453 Solid-State Drive Replacement
Was du brauchst
  1. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: Schritt 3, Bild 2 von 2
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Solid-State Drive: Schritt 6, Bild 1 von 2 Acer Chromebook 15 C910-C453 Solid-State Drive Replacement, Solid-State Drive: Schritt 6, Bild 2 von 2
    • Remove the screw at the left of the drive.
  7. Acer Chromebook 15 C910-C453 Solid-State Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the drive by pulling it gently to the left.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S15-G1, Banghart Spring 2017 Mitglied von Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
5 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 47
Insgesamt: 5,731
