Zum Hauptinhalt wechseln
Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement
Was du brauchst
  1. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 1 von 1
    • Place the device on a flat surface with the bottom facing upwards.
  2. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the eighteen 6 mm screws from bottom of the device using a Phillips #0 screwdriver.
  3. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • With the plastic opening tool, pry along the edges of the bottom slowly to separate the back cover.
    • Be careful not to damage or crack the back cover of the device.
  4. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    • Carefully remove the back cover.
  5. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 2
    • Locate the Wi-Fi card. It will be white chip beside the motherboard.
    • Remove the 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
  6. Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 3 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 6, Bild 2 von 3 Acer Chromebook 15 CB3-532-C6T1 Wi-Fi Card Replacement: Schritt 6, Bild 3 von 3
    • Gently grab the edges of the Wi-Fi card and pull it out from the motherboard.
    • Carefully remove the two coaxial antenna cables that attach the Wi-Fi card to the motherboard. One is black and the other is white.
    • Have your new replacement Wi-Fi card ready to place back in the slot.
Abschluss
Avinesh Mohanaranjan
183 Reputation
1 Anleitung geschrieben
York University, Team E-17, Melo-Thaiss Fall 2021 Mitglied von York University, Team E-17, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG17
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 37
Insgesamt: 736
