Einleitung
This guide will walk you through replacing the back cover of your Acer Chromebook 15 CB5-571-C09S.
Was du brauchst
Place the device on a flat surface faced down so that the fan vents are at the top of the device.
Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
Use a plastic opening tool to pry open the back cover around the edges of the device.
Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
2 weitere Personen haben diese Anleitung absolviert.
