Einleitung
This guide will walk you through replacing the SSD in your Acer Chromebook 15 CB5-571-C09S.
Was du brauchst
Place the device on a flat surface faced down so that the fan vents are at the top of the device.
Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
Use a plastic opening tool to pry open the back cover around the edges of the device.
Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
