Einleitung
This guide will walk you through replacing the track pad in your Acer Chromebook 15 CB5-571-C09S.
Was du brauchst
Place the device on a flat surface faced down so that the fan vents are at the top of the device.
Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
Use a plastic opening tool to pry open the back cover around the edges of the device.
Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
Disconnect the battery connector from the motherboard using two plastic opening tools.
Use two of the plastic opening tools on either edge of the battery connector and carefully pull out the battery connector out from the motherboard.
Once the battery has been disconnected from the motherboard it can easily be removed from the device.
Grab the top edge of the battery and carefully pull it up and out of the device towards you.
Remove the track pad connector from the motherboard.
Use two of the plastic opening tools to grab either side of the track pad connector and carefully pull it out from the motherboard.
Grab the track pad from its corners and carefully pull it up and out of the device.
