Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The battery powers the laptop. Before taking anything out of the laptop, always remove the battery to avoid shocking yourself and damaging other components. Over time, the battery will lose the ability to charge. Replace the battery with a new one to regain your original battery life.
Ersatzteile
  1. Place the laptop on a flat surface with the bottom side facing up. Place the tip of a spudger or finger into the hole on the battery release slider.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Use the spudger to move the slider to the right and hold it there. With the slider held, use your other hand to pull the battery back away from the laptop.
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
Abschluss
14 weitere Nutzer haben diese Anleitung absolviert.
Adam Whitmarsh
972 Reputation
1 Anleitung geschrieben
Cal Poly, Team 13-3, Forte Fall 2013 Mitglied von Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
5 Mitglieder
14 Anleitungen geschrieben
I actually used a ball point pin instead of a spudger (its dark, I'm female and I am not walking to Office Max in this neighborhood by myself). And voici, the battery came off. Now to see if the damned computer will reboot.
Daphne Macklin - Antwort
I have a C710-2856, which uses a 14.8V battery. All of the extended batteries say they won't work on the 14.8V battery .Does anyone know of an extended battery that WOULD work with the 14.8V version of this Chromebook. I can up the RAM to 16GB, and I can put any SSD, but the only weakness left is the short battery life.
Tom Dison - Antwort
I wish I had an answer for you! I'm looking into the same thing. All the extended batteries are 11.1 v and not compatible with the 14.8 v need of the C710-2856. Did you ever get an answer to this? perhaps elsewhere? Thanks!
Cornell Gunter -
i have a C710-2815? what kind of battery do i need for a replacement
sudanna soetome - Antwort
It is a sad state of things when being female makes you unsafe. On the other hand, you won't have the American Dream drafted away from you.
xcoconino9 - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 20
Letzten 30 Tage: 89
Insgesamt: 27,940
