Zum Hauptinhalt wechseln
Acer Chromebook C710-2833 Hard Drive Replacement
Was du brauchst
  1. Acer Chromebook C710-2833 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C710-2833 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the screw and cover safely to the side for now.
  3. Acer Chromebook C710-2833 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook C710-2833 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Locate the hard drive.
    • Locate the four 3 mm Phillips #00 screws on each corner of the hard drive.
    • Take your driver with the PH00 bit attached and unscrew all four screws.
    • Place the screws off to the side for now.
  5. Acer Chromebook C710-2833 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook C710-2833 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Once all the screws are out, gently pull the hard drive out as pictured.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S1-G6, Nance Fall 2017 Mitglied von USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 1,201
